									18kPV (FAAB-2727): &quot;Time+SOC&quot; AC charge ignores the Stop-SOC target — charges to full; AC Charge Power setpoint also ignored - 18kPV				            </title>
            <link>https://forum.eg4electronics.com/community/18kpv/18kpv-faab-2727-timesoc-ac-charge-ignores-the-stop-soc-target-charges-to-full-ac-charge-power-setpoint-also-ignored/</link>
            <lastBuildDate>Wed, 14 Oct 2026 07:27:00 +0000</lastBuildDate>
                        <title>RE: 18kPV (FAAB-2727): &quot;Time+SOC&quot; AC charge ignores the Stop-SOC target — charges to full; AC Charge Power setpoint also ignored</title>
                        <link>https://forum.eg4electronics.com/community/18kpv/18kpv-faab-2727-timesoc-ac-charge-ignores-the-stop-soc-target-charges-to-full-ac-charge-power-setpoint-also-ignored/#post-21422</link>
                        <pubDate>Mon, 06 Jul 2026 20:36:42 +0000</pubDate>
                        <description><![CDATA[Follow-up / clarification (please disregard my 85% example):Since posting I identified a SEPARATE issue with my battery&#039;s SOC gauge — the pack&#039;sreported State of Charge freezes near 80% and ...]]></description>
                        <content:encoded><![CDATA[<p>Follow-up / clarification (please disregard my 85% example):<br /><br />Since posting I identified a SEPARATE issue with my battery's SOC gauge — the pack's<br />reported State of Charge freezes near 80% and then jumps straight to ~100%, skipping<br />81–99%. (3rd-party Docan/JBD-type BMS; reported to the battery vendor separately.)<br /><br />That means my Stop-85% example is NOT clean evidence — the inverter never actually<br />"saw" 85%. Please set that one aside.<br /><br />The core finding is unaffected and rests on gauge-independent tests: with Stop SOC set<br />to 45% — a mid-range value the gauge reports accurately (43 → 45 → 46 → 47 in order) —<br />"Time + SOC" grid-charged straight through 45% at full rate (~11 kW) with no throttle<br />and no stop. A Stop-35% test behaved identically. So Time + SOC ignores the Stop-SOC<br />target regardless of any gauge behavior.<br /><br />Findings 2 (AC Charge Power setpoint ignored) and 3 (SOC mode stops cleanly at 53%)<br />are also independent of the gauge. Happy to share the 15-second logs and a chart.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/18kpv/">18kPV</category>                        <dc:creator>sv1985pg</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/18kpv/18kpv-faab-2727-timesoc-ac-charge-ignores-the-stop-soc-target-charges-to-full-ac-charge-power-setpoint-also-ignored/#post-21422</guid>
                        <title>18kPV (FAAB-2727): &quot;Time+SOC&quot; AC charge ignores the Stop-SOC target — charges to full; AC Charge Power setpoint also ignored</title>
                        <link>https://forum.eg4electronics.com/community/18kpv/18kpv-faab-2727-timesoc-ac-charge-ignores-the-stop-soc-target-charges-to-full-ac-charge-power-setpoint-also-ignored/#post-21414</link>
                        <pubDate>Sun, 05 Jul 2026 21:16:19 +0000</pubDate>
                        <description><![CDATA[Hardware: EG4 18kPV (18KPV-12LV), firmware FAAB-2727, with a 3rd-party Docan 48 kWh LiFePO₄ in closed-loop (comms confirmed — pack SOC matches the inverter, BMS Charge/Discharge = Allowed)....]]></description>
                        <content:encoded><![CDATA[<p>Hardware: EG4 18kPV (18KPV-12LV), firmware <strong>FAAB-2727</strong>, with a 3rd-party Docan 48 kWh LiFePO₄ in <strong>closed-loop</strong> (comms confirmed — pack SOC matches the inverter, BMS Charge/Discharge = Allowed).</p>
<p>I logged <strong>read-only Modbus telemetry every 15 seconds</strong> and ran controlled A/B tests, reading each setting back from the holding registers to confirm it applied. Two behaviors don't match the documentation/UI:</p>
<p><strong>1) "Time + SOC" mode ignores the Stop-SOC target.</strong><br />Expected: charge during the window <strong>and</strong> only up to the Stop-SOC, then stop.<br />Observed: it charges the <strong>entire window regardless of SOC</strong>, overshooting to full.</p>
<ul>
<li><strong>Test A:</strong> Stop SOC set to <strong>85%</strong> at <strong>14:09 — 16 minutes BEFORE</strong> the 14:25 window opened (ruling out "changed mid-window"). Battery grid-charged <strong>straight through 85% to 99%</strong> by the window's end. Net solar (PV − load) was negative after ~15:15, so the whole 56% → 99% climb was <strong>grid</strong> charging.</li>
<li><strong>Test B (clean retest):</strong> Time+SOC, <strong>Stop 45%</strong>, set before the window, wide band. Charged <strong>straight through 45% → 47%+ at full rate, with no throttle</strong> at the target.</li>
</ul>
2733
<p><strong>2) AC Charge Power (kW) setpoint is ignored.</strong></p>
<ul>
<li>Set to <strong>3 kW</strong> → charged <strong>~8.6 kW</strong>.</li>
<li>Set to <strong>10 kW</strong> → charged <strong>~8.4 kW</strong>.<br />Identical. Actual rate tracked only the <strong>BMS charge-current limit</strong> (~150 A at 50% SOC, tapering), never the kW setpoint.</li>
</ul>
<p><strong>3) For contrast — "SOC"-based mode DOES stop correctly</strong> (same battery, same live SOC):<br />With <strong>Based On = SOC, Stop 53%</strong>, grid draw went <strong>873 W → 0 exactly at 53%</strong> and stayed at 0 even as house load rose. This shows the inverter <strong>has correct SOC and can act on it</strong> — which points the Time+SOC failure at the <strong>charge-control logic</strong>, not the battery or its comms.</p>
<p><strong>Questions:</strong></p>
<ol>
<li>Is the Time + SOC behavior (1) intended, or a firmware bug? I expected it to stop at the target within the window.</li>
<li>Is the AC Charge Power (kW) setpoint supposed to cap grid charge current? It appears ignored.</li>
<li>If (1) is intended, what's the supported way to grid-charge to a target SOC <strong>within a time window</strong> and then stop? (SOC mode stops at target but ignores the window, risking charging during peak-rate hours.)</li>
</ol>
<p>Happy to share full 15-second logs, register snapshots, and charts. Anyone else on FAAB-2727 seeing the same?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/18kpv/18kpv-faab-2727-timesoc-ac-charge-ignores-the-stop-soc-target-charges-to-full-ac-charge-power-setpoint-also-ignored/#post-21414</guid>
