									Configuring the (NO2,COM2) dry contacts in 6000xp - Inverters				            </title>
            <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/</link>
            <lastBuildDate>Thu, 19 Nov 2026 02:21:15 +0000</lastBuildDate>
                        <title>RE: Configuring the (NO2,COM2) dry contacts in 6000xp</title>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16644</link>
                        <pubDate>Fri, 20 Jun 2025 20:11:36 +0000</pubDate>
                        <description><![CDATA[@krzysiek_kta Thank you for the feedback and yes, I can definitely share this with our team!]]></description>
                        <content:encoded><![CDATA[@krzysiek_kta <br />Thank you for the feedback and yes, I can definitely share this with our team!]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/inverters/">Inverters</category>                        <dc:creator>EG4 Eric</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16644</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16629</link>
                        <pubDate>Fri, 20 Jun 2025 00:56:29 +0000</pubDate>
                        <description><![CDATA[Can it be put on the whish list for future firmware upgrades?
Dry Contact behavior governed by GEN start/stop voltage/SoC settings doesn&#039;t make much sense as the GEN contacts are already go...]]></description>
                        <content:encoded><![CDATA[<p>Can it be put on the whish list for future firmware upgrades?</p>
<p>Dry Contact behavior governed by <span>GEN start/stop voltage/SoC settings doesn't make much sense as the GEN contacts are already governed by thhat... just my 5 cents..</span></p>
<p> </p>
<p>THX</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/inverters/">Inverters</category>                        <dc:creator>Krzysiek_KTA</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16629</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16619</link>
                        <pubDate>Thu, 19 Jun 2025 18:33:36 +0000</pubDate>
                        <description><![CDATA[@krzysiek_kta This is currently not possible.]]></description>
                        <content:encoded><![CDATA[@krzysiek_kta <br />This is currently not possible.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16619</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16581</link>
                        <pubDate>Sat, 14 Jun 2025 13:08:59 +0000</pubDate>
                        <description><![CDATA[UPDATE.
For some reason the COM1 NO1 and COM2 NO2 dry contacts started working today as per 5.8.2 of the Manual.
(Maybe the overnight system restart has something to do with it).
@EG4e...]]></description>
                        <content:encoded><![CDATA[<p>UPDATE.</p>
<p>For some reason the COM1 NO1 and COM2 NO2 dry contacts started working today as per 5.8.2 of the Manual.</p>
<p>(Maybe the overnight system restart has something to do with it).</p>
<p> </p>
<p>@EG4eric</p>
<p>Would it be possible to have the ability to program NO2 COM2 NC2 independently to GEN start/stop voltage/SoC settings ?</p>
<p> </p>
<p>Brgds</p>
<p> </p>
<p>K</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16581</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16578</link>
                        <pubDate>Fri, 13 Jun 2025 20:12:27 +0000</pubDate>
                        <description><![CDATA[Hallo Eric,
Thanks for reply.
Actually I wanted to use dry port to trigger the external relay switch based on the SoC of the battery. Is there any way to program the NO2/NC2 dry port behav...]]></description>
                        <content:encoded><![CDATA[<p>Hallo Eric,</p>
<p>Thanks for reply.</p>
<p>Actually I wanted to use dry port to trigger the external relay switch based on the SoC of the battery. Is there any way to program the NO2/NC2 dry port behavior ?</p>
<p>As per Manual it should be govern by "<span>Gen charge start voltage/SoC" setting. Obviously it doesn't work. NO2 opens only when the inverter is powered off and stays closed regardless of "Gen charge start voltage/SoC" setting.</span></p>
<p>I believe same applies to NO1 - the Monitoring Site shows : "<span>GEN Dry Contact: </span><span class="genDryContactText">ON" when there is no Grid connected to the inverter regardless of the <span>Gen charge start voltage/SoC setting in the system.</span></span></p>
<p><span class="genDryContactText"><span>The</span> "<span>GEN Dry Contact: </span>OFF" shows when the grid is connected to the system  - so in this case the contact works as as intended<span>.</span></span></p>
<p>Tried "<span>Gen charge start voltage/SoC" setting as </span>voltage while in Lead Acid battery mode and SoC in Lithium1 battery mode - all same. Only powering down the inverter triggers NO2 dry contacts to open.</p>
<p>Just my observation.</p>
<p> </p>
<p>Brgds</p>
<p> </p>
<p>K</p>
<p> </p>
<p> </p>
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/paged/2/#post-16578</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16573</link>
                        <pubDate>Fri, 13 Jun 2025 17:31:41 +0000</pubDate>
                        <description><![CDATA[If you are wanting for the generator to start and stop according to the charging parameters, you will need to connect to NO1 and COM1.]]></description>
                        <content:encoded><![CDATA[<p>If you are wanting for the generator to start and stop according to the charging parameters, you will need to connect to NO1 and COM1.<br /><br /></p>
1312]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16573</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16572</link>
                        <pubDate>Fri, 13 Jun 2025 14:31:38 +0000</pubDate>
                        <description><![CDATA[That is strange.  Hopefully someone from EG4 will chime in.]]></description>
                        <content:encoded><![CDATA[<p>That is strange.  Hopefully someone from EG4 will chime in.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/inverters/">Inverters</category>                        <dc:creator>Joel Brodeur</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16572</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16566</link>
                        <pubDate>Thu, 12 Jun 2025 20:59:27 +0000</pubDate>
                        <description><![CDATA[Thanks,
I found that table in the Manual, Yet after some tests it seems doesn&#039;t reflect the dry contact behavior.
I have connected two test wires to Dry contact NO2 and COM2 and it s...]]></description>
                        <content:encoded><![CDATA[<p>Thanks,</p>
<p> </p>
<p>I found that table in the Manual, Yet after some tests it seems doesn't reflect the dry contact behavior.</p>
<p> </p>
<p>I have connected two test wires to Dry contact NO2 and COM2 and it seems to be closed at the Battery voltage above the Gen charge start voltage - I have set it to 50V and with current voltage 52.3V the contact remains closed.</p>
<p>Once I switch the inverter off - the NO2 contact opens as intended.</p>
<p>weird.</p>
<p> </p>
<p>Brgds</p>
<p> </p>
<p>K</p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16566</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16565</link>
                        <pubDate>Thu, 12 Jun 2025 19:03:31 +0000</pubDate>
                        <description><![CDATA[The only difference I see is if you have grid or not.
With Grid the Gen contacts behave a little differently as it won&#039;t close the gen contacts when there is grid.]]></description>
                        <content:encoded><![CDATA[<p>The only difference I see is if you have grid or not.</p>
<p>With Grid the Gen contacts behave a little differently as it won't close the gen contacts when there is grid.</p>
1311]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16565</guid>
                        <title>Configuring the (NO2,COM2) dry contacts in 6000xp</title>
                        <link>https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16563</link>
                        <pubDate>Thu, 12 Jun 2025 15:16:54 +0000</pubDate>
                        <description><![CDATA[I was looking through manuals and online search and could not find the guidance how to configure Dry port (NO2,COM2) - are those dry contacts operate as per Gen charge Start/stop voltage?
I...]]></description>
                        <content:encoded><![CDATA[<p>I was looking through manuals and online search and could not find the guidance how to configure Dry port (NO2,COM2) - are those dry contacts operate as per Gen charge Start/stop voltage?</p>
<p>If so what is the difference from GEN Dry contacts (NO1,COM1)?</p>
<p> </p>
<p>Many Thanks</p>
<p> </p>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/configuring-the-no2com2-dry-contacts-in-6000xp/#post-16563</guid>
