									Deep Dive into Logs on 6000xp - Inverters				            </title>
            <link>https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/</link>
            <lastBuildDate>Sat, 08 Aug 2026 10:46:07 +0000</lastBuildDate>
                        <title>RE: Deep Dive into Logs on 6000xp</title>
                        <link>https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-334</link>
                        <pubDate>Thu, 31 Oct 2024 15:51:51 +0000</pubDate>
                        <description><![CDATA[@jared Perfect thank you very much.
JB]]></description>
                        <content:encoded><![CDATA[<p>@jared Perfect thank you very much.</p>
<p> </p>
<p>JB</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/inverters/">Inverters</category>                        <dc:creator>Joel Brodeur</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-334</guid>
                        <link>https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-333</link>
                        <pubDate>Thu, 31 Oct 2024 15:40:11 +0000</pubDate>
                        <description><![CDATA[Here’s a definition summary for each term:
epsVoltL1N – EPS Voltage of L1N: The emergency power supply (EPS) voltage measured between Line 1 (L1) and Neutral (N).
epsVoltL2N – EPS ...]]></description>
                        <content:encoded><![CDATA[<p>Here’s a definition summary for each term:</p>
<ul>
<li>
<p><strong>epsVoltL1N</strong> – EPS Voltage of L1N: The emergency power supply (EPS) voltage measured between Line 1 (L1) and Neutral (N).</p>
</li>
<li>
<p><strong>epsVoltL2N</strong> – EPS Voltage of L2N: The EPS voltage measured between Line 2 (L2) and Neutral (N).</p>
</li>
<li>
<p><strong>pEpsL1N</strong> – EPS Power of L1N: The active power output from the EPS on Line 1 (L1) to Neutral (N).</p>
</li>
<li>
<p><strong>pEpsL2N</strong> – EPS Power of L2N: The active power output from the EPS on Line 2 (L2) to Neutral (N).</p>
</li>
<li>
<p><strong>sEpsL1N</strong> – EPS Apparent Power of L1N: The apparent power (active and reactive combined) from the EPS on Line 1 (L1) to Neutral (N).</p>
</li>
<li>
<p><strong>sEpsL2N</strong> – EPS Apparent Power of L2N: The apparent power from the EPS on Line 2 (L2) to Neutral (N).</p>
</li>
<li>
<p><strong>eEpsL1NDay</strong> – EPS Day Energy of L1N: The total energy output from the EPS on Line 1 (L1) to Neutral (N) for a single day.</p>
</li>
<li>
<p><strong>eEpsL2NDay</strong> – EPS Day Energy of L2N: The total energy output from the EPS on Line 2 (L2) to Neutral (N) for a single day.</p>
</li>
<li>
<p><strong>eEpsL1NAll</strong> – EPS Total Energy of L1N: The cumulative energy output from the EPS on Line 1 (L1) to Neutral (N) over its operational life.</p>
</li>
<li>
<p><strong>eEpsL2NAll</strong> – EPS Total Energy of L2N: The cumulative energy output from the EPS on Line 2 (L2) to Neutral (N) over its operational life.</p>
</li>
<li>
<p><strong>pEps</strong> – EPS Power: The total active power output from the EPS across all lines.</p>
</li>
<li>
<p><strong>sEps</strong> – EPS Apparent Power: The total apparent power output from the EPS across all lines (active and reactive power combined).</p>
</li>
</ul>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/inverters/">Inverters</category>                        <dc:creator>Jared</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-333</guid>
                        <title>Deep Dive into Logs on 6000xp</title>
                        <link>https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-321</link>
                        <pubDate>Wed, 30 Oct 2024 16:54:08 +0000</pubDate>
                        <description><![CDATA[So, I have been reviewing the log files for the 6000xp.  Thinking about building a Grafana site but I want to understand the log files a bit better before diving too far in.
For my first lo...]]></description>
                        <content:encoded><![CDATA[<p>So, I have been reviewing the log files for the 6000xp.  Thinking about building a Grafana site but I want to understand the log files a bit better before diving too far in.</p>
<p>For my first look at the logs, I am looking at the EPS registers and I am wonder about some of the different items.</p>
<p>here is a snip of the logs</p>
147
<p>I understand the diff between L1 and L2 - each leg of the 240.</p>
<p>I also get the Volts on each line</p>
<p>The ones I am wondering about is the different <span style="text-decoration: underline">pEps</span> columns(CP &amp; CQ), <span style="text-decoration: underline">sEps</span> columns (CR &amp; CS), and <span style="text-decoration: underline">eEps</span> columns (CT through CW) (pretty much hoping for an understanding of the e, p, and s prefixes).</p>
<p>and how these relate to the <span style="text-decoration: underline">peps</span> and <span style="text-decoration: underline">seps</span> columns (Y&amp;Z)</p>
<p>Thanks,</p>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/inverters/deep-dive-into-logs-on-6000xp/#post-321</guid>
