									Why is the 6000XP and 12000XP not compatible with the GRIDBOSS? - Product Launches				            </title>
            <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/</link>
            <lastBuildDate>Sat, 08 Aug 2026 09:53:02 +0000</lastBuildDate>
                        <title>RE: Why is the 6000XP and 12000XP not compatible with the GRIDBOSS?</title>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-20576</link>
                        <pubDate>Fri, 30 Jan 2026 13:37:00 +0000</pubDate>
                        <description><![CDATA[@jared Why can the 6000xp or 12000xp not be AC coupled to the GridBOSS?]]></description>
                        <content:encoded><![CDATA[@jared Why can the 6000xp or 12000xp not be AC coupled to the GridBOSS?]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>SolarGear</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-20576</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-19463</link>
                        <pubDate>Mon, 20 Oct 2025 20:00:19 +0000</pubDate>
                        <description><![CDATA[I love how this forum is all but dead with no EG4 involvement.
Sad.]]></description>
                        <content:encoded><![CDATA[<p>I love how this forum is all but dead with no EG4 involvement.</p>
<p> </p>
<p>Sad. </p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>redpineapple</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-19463</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-19345</link>
                        <pubDate>Mon, 06 Oct 2025 20:15:35 +0000</pubDate>
                        <description><![CDATA[As a follow up on this.....I would like to point out that it &quot;may&quot; be possible to use other inverters (not just EG4) with the Gridboss.
The generator INPUT accepts any 240v pure sine wav...]]></description>
                        <content:encoded><![CDATA[<p>As a follow up on this.....I would like to point out that it "may" be possible to use other inverters (not just EG4) with the Gridboss.</p>
<p> </p>
<p>The generator <strong>INPUT</strong> accepts any 240v pure sine wave source to power and charge your batteries.</p>
<p> </p>
<p>Look at the 12 minute mark here - https://youtu.be/IBfWOmCjdYQ?t=5</p>
<p> </p>
<p>In theory any device (inverter / generator / etc.) that can supply pure power into the Gridboss can be coupled through the Generator port.... and possibly through the Hybrid Smart Ports as well.</p>
<p> </p>
1817
<p> </p>
<p>It may not be the <strong>INTENDED</strong> use but it will work.</p>
<p> </p>
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-19345</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-12754</link>
                        <pubDate>Tue, 18 Feb 2025 21:49:22 +0000</pubDate>
                        <description><![CDATA[I needed 200amp pass thru because of peak draw in summer also so I bought 2 12000xp&#039;s. It wasn&#039;t that much added cost if you use Polaris connectors. 1-200amp main disconnect to a 200amp 3-wa...]]></description>
                        <content:encoded><![CDATA[<p>I needed 200amp pass thru because of peak draw in summer also so I bought 2 12000xp's. It wasn't that much added cost if you use Polaris connectors. 1-200amp main disconnect to a 200amp 3-way Polaris then into each inverter. If code requires you to put in the manual transfer switch then you will only need one between the main disconnect and Polaris connector. </p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>wardo5757</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-12754</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-596</link>
                        <pubDate>Mon, 18 Nov 2024 19:37:03 +0000</pubDate>
                        <description><![CDATA[As Adam De Lay mentioned, our hybrid inverters are designed to connect to the GridBoss Hybrid Ports using the AC IN port, enabling bi-directional power flow. However, we are continually expl...]]></description>
                        <content:encoded><![CDATA[<p>As Adam De Lay mentioned, our hybrid inverters are designed to connect to the GridBoss Hybrid Ports using the AC IN port, enabling bi-directional power flow. However, we are continually exploring ways to enhance our products and will announce any future compatibility with the GridBoss as it becomes available.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>Jared</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-596</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-595</link>
                        <pubDate>Mon, 18 Nov 2024 18:32:10 +0000</pubDate>
                        <description><![CDATA[So the GridBoss at this time is designed for only Hybrid inverters.  The inverter uses the AC IN port to connect to the GridBoss because that port on a hybrid inverter allows bi-directional ...]]></description>
                        <content:encoded><![CDATA[<p>So the GridBoss at this time is designed for only Hybrid inverters.  The inverter uses the AC IN port to connect to the GridBoss because that port on a hybrid inverter allows bi-directional power flow.  It can push power up to the GridBoss to supply power to the loads (also melding with AC Coupling or grid power) or it can pull power from the grid to charge batteries.  </p>
<p>Off-Grid inverters only allow power flow in one direction on the AC In port (so you don't accidentally backfeed to the grid).  For an off-grid inverter, you would have to run two sets of cables, one for feeding power to your loads and one for taking power from the grid (when in bypass mode).  </p>
<p>I'm not sure if they're planning on anything for off-grid inverters or not.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>Adam De Lay</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-595</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-588</link>
                        <pubDate>Sat, 16 Nov 2024 19:54:57 +0000</pubDate>
                        <description><![CDATA[I also agree with this.  I am in the exact same predicament.  I am purchasing two 12000xp’s, and I am going to have to run lots of extra wiring and panels—which is the exact thing James stat...]]></description>
                        <content:encoded><![CDATA[<p>I also agree with this.  I am in the exact same predicament.  I am purchasing two 12000xp’s, and I am going to have to run lots of extra wiring and panels—which is the exact thing James stated the Gridboss was designed to eliminate. The Gridboss could solve so many issues for me.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>blpennington</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-588</guid>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-583</link>
                        <pubDate>Sat, 16 Nov 2024 07:48:15 +0000</pubDate>
                        <description><![CDATA[I agree with the Above.]]></description>
                        <content:encoded><![CDATA[<p>I agree with the Above.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/product-launches/">Product Launches</category>                        <dc:creator>koppted</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-583</guid>
                        <title>Why is the 6000XP and 12000XP not compatible with the GRIDBOSS?</title>
                        <link>https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-399</link>
                        <pubDate>Mon, 04 Nov 2024 13:14:46 +0000</pubDate>
                        <description><![CDATA[@EG4 - why are these not compatible with the new Gridboss?  Having these compatible would solve SO many problems and extra systems inbetween my service main and the inverter.
I was hoping t...]]></description>
                        <content:encoded><![CDATA[<p>@EG4 - why are these not compatible with the new Gridboss?  Having these compatible would solve SO many problems and extra systems inbetween my service main and the inverter.</p>
<p>I was hoping to be able to go with a 12000XP + Gridboss since I'm <strong>NOT</strong> selling any spare wattage back to the grid in a grid share agreement.</p>
<p>The GRIDBOSS solves my issues entirely but it won't work with the 12000XP.</p>
<p> </p>
<p>Service Main --&gt; 200 AMP Disconnect --&gt; Grid Boss</p>
<p> </p>
<p>From here I can send power to a 200 AMP Panel and or a 100 AMP sub panel.</p>
<p> </p>
<p>What was the justification for not making the XP line not work with this system? </p>
<p> </p>
<p>Because I don't sell electricity back I could (in theory) buy 2x 12000XP's for the cost of 1x 18KPV and have twice the output and input.</p>
<p> </p>
<p>The only downside is that the 12000XP only has a 100Amp grid bypass which isn't enough for extreme peak usage for me.  <strong>Only the 18KPV</strong> has a 200 amp bypass on the inverter, but I don't need to the hybrid grid sell back option.</p>
<p>The GRID boss would allow for 200AMP service to bypass the inverter and go directly to grid (which I need in my loads exceed 100 amp).  My max sustained is around 85 but the 15% rule says I should plan for more just in case.</p>
<p>How can I get 200 amps of GRID tied power to my panel through an inverter without buying an 18KPV, or a Flexboss21 + Gridboss?</p>
<p>Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/product-launches/why-is-the-6000xp-and-12000xp-not-compatible-with-the-gridboss/#post-399</guid>
