									Can someone explain this? - General Troubleshooting				            </title>
            <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/</link>
            <lastBuildDate>Wed, 14 Oct 2026 08:14:33 +0000</lastBuildDate>
                        <title>RE: Can someone explain this?</title>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20612</link>
                        <pubDate>Mon, 02 Feb 2026 23:26:34 +0000</pubDate>
                        <description><![CDATA[@jlankford Thanks for the suggestion. Actually, I did not even realize the indoor batteries had heaters. I thought only the outdoor version had them. I will have to see if there is any phone...]]></description>
                        <content:encoded><![CDATA[@jlankford Thanks for the suggestion. Actually, I did not even realize the indoor batteries had heaters. I thought only the outdoor version had them. I will have to see if there is any phone support at EG4.]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/troubleshooting/">General Troubleshooting</category>                        <dc:creator>gtsquires</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20612</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20607</link>
                        <pubDate>Mon, 02 Feb 2026 21:19:35 +0000</pubDate>
                        <description><![CDATA[@gtsquires I saw that they&#039;re indoor batteries, but plenty of people install those in unheated sheds so it seemed like a reasonable question. The 224 watt heater power was from the indoor sp...]]></description>
                        <content:encoded><![CDATA[@gtsquires I saw that they're indoor batteries, but plenty of people install those in unheated sheds so it seemed like a reasonable question. The 224 watt heater power was from the indoor spec. I have no other ideas for you, unfortunately...]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/troubleshooting/">General Troubleshooting</category>                        <dc:creator>JLankford</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20607</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20606</link>
                        <pubDate>Mon, 02 Feb 2026 20:51:22 +0000</pubDate>
                        <description><![CDATA[And another mystery. At 5 am when there is no PV activity and no battery discharge, I export power to the grid for 5 minutes.
&nbsp;]]></description>
                        <content:encoded><![CDATA[<p>And another mystery. At 5 am when there is no PV activity and no battery discharge, I export power to the grid for 5 minutes.</p>
2430
<p>&nbsp;</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20606</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20605</link>
                        <pubDate>Mon, 02 Feb 2026 20:44:56 +0000</pubDate>
                        <description><![CDATA[@jlankford These are the INDOOR wall mount batteries. Per the manual, the heaters will come on at 32 F and turn off at 41 F. My basement temps might get into the 60s but definitely not cold ...]]></description>
                        <content:encoded><![CDATA[@jlankford These are the INDOOR wall mount batteries. Per the manual, the heaters will come on at 32 F and turn off at 41 F. My basement temps might get into the 60s but definitely not cold enough to turn on the heaters.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20605</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20604</link>
                        <pubDate>Mon, 02 Feb 2026 19:02:29 +0000</pubDate>
                        <description><![CDATA[How cold are these batteries? My first guess is that this is caused by heater discharge.
FYI, the 18Kpv EPS standby consumption won&#039;t look like this - that discharge stays under the radar a...]]></description>
                        <content:encoded><![CDATA[<p>How cold are these batteries? My first guess is that this is caused by heater discharge.</p>
<p>FYI, the 18Kpv EPS standby consumption won't look like this - that discharge stays under the radar as far as SOC reporting is concerned. i.e. the SOC doesn't change if the only consumption is from EPS idle.</p>
<p>From the specs, the heaters will consume 448 watts, which amounts to 10.7 kWh, or 37% of your SOC in a 24 hour period if the heaters are running continuously.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20604</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20603</link>
                        <pubDate>Mon, 02 Feb 2026 18:22:35 +0000</pubDate>
Here are the graphs for 2/1/26 and 2/2/26. What do you surmise, or what would you expect to see?]]></description>
<p>Here are the graphs for 2/1/26 and 2/2/26. What do you surmise, or what would you expect to see?</p>
2428
2429]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20603</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20602</link>
                        <pubDate>Mon, 02 Feb 2026 16:38:25 +0000</pubDate>
                        <description><![CDATA[What does your vBat graph look like?]]></description>
                        <content:encoded><![CDATA[<p>What does your vBat graph look like?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20602</guid>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20600</link>
                        <pubDate>Mon, 02 Feb 2026 15:04:13 +0000</pubDate>
                        <description><![CDATA[And it is still happening - day 2. Am I powering the universe?
I do not know if it is significant, but when I &quot;READ&quot; this, it always times out. So there is some sort of communications iss...]]></description>
                        <content:encoded><![CDATA[<p>And it is still happening - day 2. Am I powering the universe?</p>
2424
<p>I do not know if it is significant, but when I "READ" this, it always times out. So there is some sort of communications issue with the batteries.</p>
2425
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20600</guid>
                        <title>Can someone explain this?</title>
                        <link>https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20595</link>
                        <pubDate>Sun, 01 Feb 2026 21:07:59 +0000</pubDate>
                        <description><![CDATA[How/why has my battery SOC decreased from 88% to 81% overnight with no battery discharge? System is 18kPV hybrid inverter with 2 - 280Ah indoor wall mount batteries.]]></description>
                        <content:encoded><![CDATA[<p>How/why has my battery SOC decreased from 88% to 81% overnight with no battery discharge? System is 18kPV hybrid inverter with 2 - 280Ah indoor wall mount batteries.</p>
2422]]></content:encoded>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/troubleshooting/can-someone-explain-this/#post-20595</guid>
