									Field Impact Notice – 314Ah WallMount Charge Rate Suppression - Technical Support Bulletins (TSB)				            </title>
            <link>https://forum.eg4electronics.com/community/tsb/field-impact-notice-314ah-wallmount-charge-rate-suppression/</link>
            <lastBuildDate>Sat, 08 Aug 2026 10:50:44 +0000</lastBuildDate>
                        <title>RE: Field Impact Notice – 314Ah WallMount Charge Rate Suppression</title>
                        <link>https://forum.eg4electronics.com/community/tsb/field-impact-notice-314ah-wallmount-charge-rate-suppression/#post-20358</link>
                        <pubDate>Sat, 10 Jan 2026 16:39:26 +0000</pubDate>
                        <description><![CDATA[The one on the official EG4 electronics website did not work.  The one posted on the EG4 community forum did work.  The file sizes are also different.  Why not replace the firmware .bin file...]]></description>
                        <content:encoded><![CDATA[<p>The one on the official EG4 electronics website did not work.  The one posted on the EG4 community forum did work.  The file sizes are also different.  Why not replace the firmware .bin file on the link below with the one on the EG4 website:</p>
<p>&nbsp;</p>
<p>https://forum.eg4electronics.com/community/314ah-indoor-wallmount/firmware-update-for-314ah-indoor-wall-mount/#post-20312</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/tsb/">Technical Support Bulletins (TSB)</category>                        <dc:creator>GoingSolar</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/tsb/field-impact-notice-314ah-wallmount-charge-rate-suppression/#post-20358</guid>
                        <title>Field Impact Notice – 314Ah WallMount Charge Rate Suppression</title>
                        <link>https://forum.eg4electronics.com/community/tsb/field-impact-notice-314ah-wallmount-charge-rate-suppression/#post-20329</link>
                        <pubDate>Thu, 08 Jan 2026 16:47:35 +0000</pubDate>
                        <description><![CDATA[Field Impact Notice – 314Ah WallMount Charge Rate Suppression
SummaryThe firmware shipped on the initial batch of EG4 314Ah Indoor WallMount batteries (FW Version Z03T13) features a bug in ...]]></description>
                        <content:encoded><![CDATA[<p id="isPasted" data-xf-p="1"><strong>Field Impact Notice – 314Ah WallMount Charge Rate Suppression</strong></p>
<p data-xf-p="1"><strong>Summary<br /></strong>The firmware shipped on the initial batch of EG4 314Ah Indoor WallMount batteries (FW Version Z03T13) features a bug in which the charge rate of the battery is reduced to 15A (~750W) at temperatures above 65 °F.</p>
<p data-xf-p="1"><strong>Customer Impact<br /></strong>Batteries with FW Version Z03T13 active will experience a significant reduction in allowable charge rate, impacting the system’s ability to reliably recharge the batteries in a reasonable amount of time independent of the power availability on site. Depending on the system configuration, excess solar will be sold to the utility or curtailed to zero.</p>
<p data-xf-p="1"><strong>Resolution<br /></strong>A new firmware (FW Version Z03T17) has been made available which resolves this issue and allows the full charge rate of the battery in line with the temperature ranges indicated on the specification sheet for the battery.</p>
<p data-xf-p="1">This new firmware can be found on<span> </span><a href="https://eg4electronics.com/categories/batteries/eg4-wallmount-314ah-indoor-battery/" target="_blank" rel="noopener noreferrer"><strong>EG4Electronics.com</strong></a><span> </span>under the 314Ah Indoor WallMount product page: EG4 WallMount 314Ah Indoor Battery - EG4 Electronics.</p>
<p data-xf-p="1">314Ah WallMounts deployed with an EG4 hybrid inverter (kPV or FlexBOSS) and with an internet connection can be updated over-the-air (OTA) by your installer. Batteries deployed with an off-grid (XP) inverter or without an internet connection will require an RS485 adapter (EG4 USB Read/Write Cable - Signature Solar) and a Windows computer. The write up on how to update using an RS485 adapter can be found in the .zip file containing the most up to date firmware.</p>
<p data-xf-p="1">Please call<span> </span><strong>EG4 Support</strong><span> </span>at <strong>903-609-1988</strong><span> </span>for additional support with your system.</p>]]></content:encoded>
						                            <category domain="https://forum.eg4electronics.com/community/tsb/">Technical Support Bulletins (TSB)</category>                        <dc:creator>EG4 Eric</dc:creator>
                        <guid isPermaLink="true">https://forum.eg4electronics.com/community/tsb/field-impact-notice-314ah-wallmount-charge-rate-suppression/#post-20329</guid>
