6000xp power on and...
6000xp power on and off coninuously
(@nolensb)
I installed my new 6000xp
firmware: ccaa-180D0E
It was running in AC Bypass. The battery wasn't connected yet, because
I hadn't had time to configure everything yet. I was running in bypass
just to have my circuits back.
Wiring config was: 200amp main panel -> 100amp subpanel -> 50amp
breaker to 6000xp -> to 50amp subpanel.
It ran fine from Friday to Sunday night about 11:30 PM. Then the EPS
started turning on and off continuously. The screen would stay on and
the "normal" icon would flash with the clicks of the relays. I didn't
see any errors and it didn't give any faults.
To get my circuits back I unhooked the grid and load from the
I'm getting 120v L1 and L2 to neutral. 240v L1 to L2. 120V L1 to ground and L2 to ground. .05V Ground to Neutral.
Moderator
Online Support
Were there any error codes reported with this? Also, if you are able to DM the serial number for the inverter, I can take a look at it on the monitoring system.
(@nolensb)
Direct message sent. No codes were thrown.
