FlexBoss 21 what is...
Question FlexBoss 21 what is the maximum output amps at 120vac and 240vac
(@jsteelea45)
What is my Maximum AC output voltage at at 120vac and 240vac  ? Also now many FlexBoss 21's can I parallel together ? If I parallel them together do I have only one AC output going to my single breaker box or would I need to set up sub panels for each FlexBoss 21 inverter ? In other words can I hook all my outputs of my Flexboss 21's to my single AC breaker Panel. I hope this makes since I really need to know.
Posted : March 7, 2025 11:59 pm
According to specs, it is 50A ac output, up to 16 in parallel. I doubt you would be able to feed them directly to your service panel or main.
Probably something like the feeders from the Flex boss into 50A breakers in a panel with a main breaker that can handle the combined output.  Then from there to your service panel or main.  I would talk to a local electrician regarding code.
Posted : March 8, 2025 7:38 pm
Some diagrams from EG4
EG4 FlexBOSS21 System Wiring Diagrams_v1.1
Posted : March 8, 2025 7:41 pm
(@jsteelea45)
Posted by: @jsteelea45
thank you so much !
Posted : March 8, 2025 8:37 pm
(@jsteelea45)
Posted by: @joel-brodeur
Thank you so much 1
