Design advice neede...
Design advice needed for newbie
(@rasolar)
Hello.  I want to add batteries to an existing system that is made up of 3 independent older inverters totaling about 10kW, all ground-mounted, and one 19.2kW rooftop Enphase system.  Here are my goals:
  1. Achieve as close to 100% self-sufficiency as possible with grid available as a rarely used backup.
  2. Make full use of my existing solar to power loads and charge batteries.
  3. Be able to physically disconnect the grid whenever I want, probably by manually overriding an ATS.
  4. Support all loads on battery (whole home backup)
  5. I don't care about selling back to the grid since my NEM2 contract (California) expired.
From what I can tell, I want the power specs of a FlexBOSS21 with the AC-coupling feature of a GridBOSS.  I already have disconnect switching in place, so those GridBOSS features are redundant.
Here's my tentative plan:
  1. Install a GridBOSS and EG4 inverters, possibly 2 or 3 FlexBOSS21s
  2. AC couple the Enphase system to the GridBOSS.
  3. Retire the old inverters and bring the PV strings to the new inverters
  4. Add batteries to the new inverters.
Here are some questions:
  1. Does the tentative plan sound reasonable?  Is there a better way?
  2. Will the GridBOSS be able to run the Enphase system and keep it running when grid power is off?
  3. If yes to 2, can the AC coupled Enphase system charge batteries while simultaneously supplying power to loads?
  4. If the grid is down for multiple days, will everything be fully functional?  (EG4 inverters, GridBOSS, AC coupled PV, DC PV from EG4 inverters, and batteries)
  5. Can the GridBOSS function with nothing connected to its grid terminals?
I know this post is pretty long, so thanks if you made it this far!
dfwtinker
(@dfwtinker)
Good Afternoon.
Just a quick question from the curious, as I too am beginning to plan my "next phase".  Why did you choose the GridBOSS over the 12000xp?  It would seem to me that you solve a lot of your problems (while moving a long way towards meeting most of your goals) using a 12000xp AND save a lot of money that you could use elsewhere.
To keeping  the sunny side up!  🍺
L8r
(@rasolar)
@dfwtinker it's a good question.  I would certainly be ok with saving/repurposing funds. 🤑
If I'm reading correctly, the 12000XP can manage 62.5A on the smart port for AC coupling while the GridBOSS is rated up to 80A on port 2 and 125A on port 1.  My 19.2kW Enphase system is theoretically 80A.  I think that rules out 12000xp for me, but would love to hear otherwise if I'm mistaken.
dfwtinker
(@dfwtinker)
@rasolar
Yep!  That it does!!  Grin
(@rasolar)
I think I could also use 18kPV and do away with the GridBOSS, but the cost difference isn't much.  Might as well go with newer inverters and higher capacity.
dfwtinker reacted
dfwtinker
(@dfwtinker)
@rasolar
Agreed!
