Eg4 ChargeVerter se...
Question Eg4 ChargeVerter setup
 Kfar
(@kfar)
I'm using my eg4CV to charge the Anker F3800 + EXBattery thru the XT60 DC connection. While connecterd to their grid using 230v it charges at 1150 Watts. Voltage: 52.0v SocStart 0.50% Battery Start 49.0v  Current 026.0 A  Soc Stop 100%  Battery Stop 57.0v
The max DC input per port is 1200 Watts. When switching to battery for powering my home transfer switch ,it will only will only us 16.5 v and 26.0 A at 415 watts.
Is there a different setting I should use when charging with 230 V ?
I'm new to all of this using Battery Power. I was using a Generator before.
Thank You for any wisdom
Kfar
