Uninstalling Mini-S...
Uninstalling Mini-Split for Warranty
(@davidt)
I have to uninstall an EG4 12000BTU Hybrid Mini-split to return to EG4 for warranty repair/replace. Do I just go backwards from the install? Will the lines reseal or do I need to evacuate the system and save the freon? Pulling entire line set and wiring is going to be no fun. Any suggestions would be appreciated.
(@krzysiek_kta)
I had my mini split RMA replaced (outdoor unit only) . I had the same concern with pre-charged line set. Therefore I talked with the vendor and made the following arrangements:
Placed order for new Unit and paid for it upfront. It was agreed that once I ship the RMA unit full refund will be issued. And indeed got refund right away once FedEx picked up the RMA unit.
The advantages of such arrangements were:
The new unit came full with cables and pre-charged line set.
I just swapped the RMA unit with new one using existing cables and line set. Tested and all worked.
I might have lost some of the line set contents during the swap ( just isolated the RMA unit from line set first - one might try to isolate the outdoor unit while running - ref to YouTube videos how to collect contents of line set with outdoor unit)
Basically replacement outdoor unit works with the old setup without any issues since then.
Hope that might help your case. But if your indoor unit is included in RMA.... then replacing line set with new one is.... No FUN indeed.
Brgds
K
(@davidt)
@krzysiek_kta Thanks for the response. Unfortunately EG4 wants the entire mini-split shipped to them for testing.
(@krzysiek_kta)
Well,
I managed to diagnose the issue with EG4 remotely - the main control board was found faulty. Had it replaced twice and eventually RMA entire outdoor unit.
But in your case might be something different. Good Luck
Brgds
K
(@lyrawinslow)
you davidt can watch this video maybe it will help
(@davidt)
