Conformal Coating &...
Question Conformal Coating & Corrosion Protection
(@mufindr)
Can't find any data on invironental protection for the Off-Grid inverters. The ideal solution for us would be the EG4 6000 XP, but might have to look at Hybrid inverter.
Looking for any information on locating inverter close to the ocean in typical 80F/30c high humidity environment.
Lighning and power outages common in our application.  Currently using a older technology PSW inverter /charger with Lead acid batteries. Will replace with solar Lifepo4 solution.  Off-grid is good enough.
Our typical peak load is 2 to 3kw.  We are located in the DR
