Flexboss 21
Question Flexboss 21
 Red
(@red)
I've had this system about 2 months already. I have it set to peak shaving between 9am to 9pm and ac charging immediately after 9pm to 9am to a 100percent SOC. I have two eg4 pros indoor. It'll pv charge  charge and use the battery throughout the day, it'll run on the battery up until 7 and starts running from the grid and charges the batteries at constant 600watts. The cut off discharge is at 20 percent, start peak at 30 percent. By the time 7pm comes around by batteries are floating around 80-90 percent. It just started 1 removed link My ac charge is set between 21:05 to 8:55 as a buffer in case there's a time delay. Peak is at 9 to 21:00. So I'm not sure why this just started happening. Any input would be appreciated.
(@jordan)
Please describe how you want your system to function.  Peak Shave is probably not what you are wishing for, all this does it keep your electrical usage from the grid from exceeding a certain threshold, it will still use power from the grid below whatever threshold that you set.
In my system, I am on a Time Of Use plan from my utility so I force discharge from 2PM to 8PM and charge from 12PM to 8AM to reduce my utility bill.  Is this the type of thing you are trying to achieve?
Jordan
