EG4 Wall Mount Pros...
EG4 Wall Mount Pros (Optimal Settings for Optimal Performance and longevity
6 Users
Bluetrader222
(@bluetrader222)
Hello team,
I have 3 Wall Mount Pros along with Sol Ark 15K in an open loop. The Batteries are set as follows"Float" 53.8; Absorption/Equalization 56.0V...Here is a screenshot of my settings:
Then I have them to drain to 15% at night and charge to 100% during sun hours . Is there a graph for SOC vs Voltage for this specific battery? Not sure how this inverter does the calculations
Thoughts on Optimal Setting?
Jarrett
(@jarrett)
Technical Solutions Manager
Having the Float that low is good for Lead Acid settings, but I would recommend Closed-Loop since they are Lithium batteries. I also know how SolArk gets when you closed loop with our batteries, so do what you've gotta do to keep your warranty.
You're getting you ~80% DOD so, that's good. Aside from that, I think everything looks good. I can't think of anything I would change.
Bluetrader222
(@bluetrader222)
Hi Jarrett,
Then what should the Float be? The spec see says charger setting for float is 54V+/- 0.2. So 54-0.2 =53.8V
Sorry what is 80% DOD? I dont mine trying close loop.
Bluetrader222
(@bluetrader222)
I did switch to close loop and trying to figure out the details.
For the EG4 Wall Pro spec sheet, what voltage (V) for a 10%, 0% state of charge? I have Battery Empty 47V.
20% SOC = X volts?
10% SOC = X volts?
0% SOC = 47 Volts? (is this correct?)
Bluetrader222
(@bluetrader222)
So here is a screenshot of my Inverter Sol Ark 15K Closed Loop stating 10% SOC = 50.6V. Is this the true 10% SOC at this voltage? I don't know. Does EG4 have a chart for the EG4 Wall Pro battery of Voltage vs SOC chart? That way I can match what 10% state of charge is? See screenshots below:
WhatsApp Image 2024 10 22 at 08.05.09 f0ddee19
WhatsApp Image 2024 10 22 at 08.05.09 6f946463
Page 1 / 3
