new 48v 51.2 100 ah...
Question new 48v 51.2 100 ah batteries
(@sleezeballs09)
I received 2 new 48 v server rack batteries and I have an Anker F3800  and charged them up each seperately ,and they will operate seperate for now because of the common ground issue, do i need to do the update before running these batteries and if they are seperate what would i change the pins to ,This is new to me ,Thank you
What is the "common ground issue" that you mentioned?
(@sleezeballs09)
@jlankford the common ground issue is with the Anker f3800 you cant supply dc volts from two sources that share the same ground  into the solar inputs it will detect it and cut the source off,so aslong as you have 2 different power sources & grounds you can charge and use the 220 output from the inverter. makes for a little bit of a pain but there arent many ways around it. right now everything is working
