Outdoor Wall Mount ...
Outdoor Wall Mount Battery Balance
(@doodadsdave)
I have 2ea Wall Mount outdoor batteries that I’ve had for a year. I’ve been delayed in installing them due to health issues but am finally getting around to it. The batteries were around 55% so I’m trying bring them both up to 100% individually before I parallel them. I have one battery connected and  it’s almost 100%. Now, to bring the second battery up….I disconnect the first battery then connect the second, do I set the dip sw to position 2, or does the sw position have to be set since I’ll only be charging. I’m using a 6000XP connected to grid for charging.
I think you have to set each battery as "master" while you are connecting and charging them individually. Then when you later connect them in parallel you'll decide which one to make Batt_01 or Batt_02.
