3rd Solar Array Not...
Question 3rd Solar Array Not Showing Any Wattage Power
(@eshultz99)
I have (2) 6000XPs in parallel. First two solar arrays connected to one 6000XP. The voltages are always around 220VDC. The display shows 1000-2000 Watts.  I have a 3rd solar array connected to the other 6000XP. The voltage is 110VDC most of the time. The inverter sees the voltage but always showing 0 Watts.  Is the 3rd Array voltage too low?  I have setting 2 set for S = Two independent strings.
Any thought?
Thanks
From the spec sheet.  Min 100V +- 10V for start up.  Min operating 120V
Hope this helps,
(@eshultz99)
Thanks Joel, I rewired the array to produce 220V and it is operating now.
