EG4 3000 EHV-48 Fau...
EG4 3000 EHV-48 Fault code 4 (Over temperature of PV Module)
(@jdfarmer)
I have 2 EGV 3000s in parallel, single phase (120v),  each connected to a 2400watt array. Since the workload is small I typically have the slave unit in standby mode so it is acting as a charge controller.  Today on a bright sunny day this unit keeps throwing a fault code 4.  I have reset the unit and it ran fine for a while, however it is alarming again.  This time I disconnected the solar array and reset the unit and reconnected the solar array and it immediately set the fault code again.  Any help would be greatly appreciated.
