Using the Chargever...
Question Using the Chargeverter GC to Charge Server Rack Batteries
(@m0nkeyb0y)
Hello,
Here is the equipment I have that is relevant to this post:
EG4 Chargeverter GC
2 x Epoch 48V 100Ah 5.12kWh - Self-Heating Server Rack Lithium Battery
The first part of my question is whether or not the following seems like an acceptable way to use the Chargeverter to charge my batteries. The Chargeverter has a NEMA L14-30 plug for connecting to a generator. My plan is to connect it to grid power using a NEMA 14-50 plug in my garage for charging my EV using this adapter cable.
The next part of my question is in regards to connecting the Chargeverter to my batteries.
The Chargeverter comes with these connection wires:
PXL 20250125 150217276
My batteries do not have ring connections on them. They also have the quick connect plugs that one side of these cables have. I have seen YouTubers using this cable to connect to a bus bar then using another cable like it to connect from the bus bar to their batteries. Would it be possible to just use battery paralleling cables to connect directly from the Chargeverter to my battery, eliminating the bus bar entirely? If so, could I use a second battery paralleling cable to connect my two batteries together and charge them at the same time using the Chargeverter?
I appreciate any advice that you may have.
Thank you!
