Use battery for Hyb...
Use battery for Hybrid mini split A/C
(@phong-vo)
I am building an RV electrical system and using a Hybrid mini split A/C 12k btu, my RV has a 96VDC 280A battery bank, can I use it to power the DC input of the A/C directly? I don't want to use an inverter because it is quite noisy. Thanks.
Posted : October 17, 2025 3:36 am
(@lyrawinslow)
Posted : December 3, 2025 6:44 am
@phong-vo
This isn’t possible; you would need solar panels for this. You could use batteries through the inverter.
Posted : December 3, 2025 4:50 pm
(@jamescartr44)
✔ 1. Inverter / Hybrid Compatible AC Chahiye
Hybrid or inverter-type mini split A/C low power par bhi chal sakta hai — isliye battery ke sath zyada compatible hota hai.
✔ 2. Battery Bank Ka Size
A/C bohat power leta hai (600W–1800W tak).
Isliye battery bank bada chahiye, jaise:
  • Lithium batteries (LiFePO₄) – best, long life, fast charging
  • 100Ah lead-acid batteries se bhi chala sakte ho, lekin backup kam hoga
✔ 3. Inverter / Solar Inverter Chahiye
Battery ko A/C se connect karne ke liye aapko:
  • Pure sine wave inverter
  • Ya solar hybrid inverter
chahiye jo A/C ka startup load handle kar sake (2–3× surge).
✔ 4. Backup Time
Example:
1-ton inverter AC ≈ 800–1200W
Agar aapke paas 24V / 200Ah lithium battery ho to approx 2–3 hours backup mil sakta hai.
✔ 5. Solar + Battery = Best
Hybrid mini split A/C ka ideal setup:
  • Solar panels
  • MPPT solar inverter
  • Lithium battery
  • Grid/utility as backup (optional)
This post was modified 4 months ago by Jamescartr44
Posted : December 10, 2025 2:18 am
