6000XP programming ...
6000XP programming advice
(@ericw)
Appreciate any advice on how to program my 6000XP…I’d like it to
1. Use solar first, then battery, then grid
2. Excess solar to charge battery.
3. When battery SOC goes below 30%, charge with grid
Thanks.
Honorable Member
Since the 6000XP is an Off-Grid inverter, it will prioritize solar and battery before using the grid. It will use solar to power the loads and to charge batteries.
To set grid to charge batteries at 30%. You can navigate to your AC charge settings and set the "AC Charge Start Battery SOC(%)" to 30% and set the "AC Charge End Battery SOC(%)" to the percentage you want them to stop charging from grid.
You can also navigate to your Discharge settings and set the "On Grid EOD SOC(%)" to 30%. Doing this will cause the inverter will stop discharging the batteries and AC will take over and power loads.
Let me know if you need further assistance.
(@ericw)
@Eric thanks!
Setting 15, AC Input Load Timer Settings should be set to off, (00:00 - 00:00) ?  What is the purpose of this setting anyway?
Honorable Member
@ericw Yes! Setting 15 is "AC first" which is the times you want the grid to power the loads.
(@alvinator)
I'm have 2 EG4 batteries connected to my 6000xp and just want the grid to keep them charged up over the winter. I've got it hooked up and have the device monitor working, but I can't seem to get them to charge? Not sure if I have the settings correct???
