EG4 18kpv brown out
Question EG4 18kpv brown out
(@george-redinger)
brownout
EG4 18kpv
firmware fAAB-1B1C
running in self consumption mode
Lights flicker in the dips.
Fridge over heated (electrical smell) but other wise still good
2 propane wall heaters (Rinnai) lost their minds and will not run now.
Software update?
Setting problem?
Can you give more details
Posted by: @george-redinger
brownout
EG4 18kpv
firmware fAAB-1B1C
Software update?
Setting problem?
Could you send me a DM of the inverters serial number? Once received, I can definitely look over all the data.
(@george-redinger)
@pawnee
MoData...
brownload
DC near shutdown
those charts show no large loads or low battery near the brown out time.
since that  brownout event, I got permission from the power company (nli.coop) to enable grid tied mode.
In grid tied mode, the inverter syncs the inverters load output voltage with the grid voltage.
This keeps the load input up to grid level (or slightly above to make exporting happen)
The concern is that (besides appliance repair from the brown out) when the grid goes down will it keep the load output voltage high enough ( 240 VAC +- 5% ) to avoid damage to the things being powered?
