I have a Gillette SPH 120 (12kw) propane generator that has a 50 amp breaker. According to the EG418Kpv manual is states:
The 18kPV can accept up to 90 Amps (21kWs) of generator power and will pass through all available
power to the loads. Therefore, the Loads subpanel can be sized up to the size of the backup generator
with a 60 Amp minimum per inverter. (See Wiring Diagrams in section 6)
So, my question is will the inverter take the charge from my generator since I have the "Batt Charge Current Limit" set a 50 Adc which is 10 Ads under the minimum?
Recently viewed by users: MTJAG 58 minutes ago.
