EG4 18KPV parameter...
EG4 18KPV parameter help?
(@gregm)
The way I would like my EG4 18KPV to work is that the grid would not input any power until the battery charge falls to 20 or 25% (maybe in the middle of the night) and then it would turn on and charge the batteries.
What parameter(s) is it that would control this and what should I set it to?
The Ruixu pamphlet says "The Low Voltage cut-off" is 44.8v
This topic was modified 10 months ago by GregM
Ensure that Battery Backup Mode is disabled, verify that you have sufficient solar and battery capacity to support your loads, and set the On-Grid Cut-Off SOC (%) to 20% or 25%.
