EG4 6000xp charging...
Question EG4 6000xp charging speed set up (PLEASE HELP)
herreraa
(@herreraa)
I purchased a 6000XP and a Veter 48V 100ah battery.  It was a gift for my dad that but the installers in his area does not know how to set the charging speed of the batery. It is taking several DAYS to go from 10 to 40%.
I really need to know what setting number controls the charging rate , and what values should be used for the Vetrer battery.
I attach the spect of the Battery and also in the attachment.
Specification Value
LiFePO4 Battery 51.2V 100AH
Nominal Voltage 51.2V
Charge Voltage 58.4V
Weight 46.5KG/102.5LBs
Energy 5120Wh
Max Continuous Charging Current 100A
Max Continuous Discharging Current 100A
Recommend Charge Current 20A (0.2C)
Max Load / Inverter Power 5120W
I  hope you can help,
Thanks
Alex
bateria cargar
I don't know much about this battery, but what do you have the charge current set to on the inverter?
Do you have the inverter on lead acid mode?
herreraa
(@herreraa)
@eric Thanks for the response. I do not know the modes used at set up , that is the problem , it was done by a technicial that know little about this inverter.
Any advice want are all the settings i need to use?
thanks
Do you know if the inverter is reading 100Ah?
If so, you can check setting #6 (Charging amperage) and make sure that it is set to between 50A-100A (20A is recommended but 100A is the max)
