EG4 6000XP Charging...
EG4 6000XP Charging time
herreraa
(@herreraa)
Hi m I am new on solar, i purchased my first inverter the 6000XP , it is still in shipping.
I want to know how long does it take to charge a lifepo4 batteri 51.3V 100A when using the grid power only.
What is the equation i shold use to calculate that. I need to learn so i can calculate again when using solar and grid
Thanks
In the most basic form, it is - the number of Amp Hours you want to put into the battery divided by the number of Amps you are putting into the battery = hours to fill the battery.
Say you have drained 10amp hours and you charge at 1 amp.  10AH/1A = 10 hours.
or
You have drained 50AH and you charge at 10A.  50AH/10A = 5 hours.
With that being said though in reality it is generally a bit different.
If the batteries have a BMS they most likely will reduce charging amps as the batteries near 100% so might take a bit longer.
Inefficiencies in the system will make it take a bit longer.
Big thing to watch/check.
Double and triple check the maximum and recommended charge rates of the batteries and do not exceed that as a charge rate.
Hope that helps some,
dfwtinker reacted
The equation for calculating charging time is ideally expressed as:
For example, when grid charging with the EG4 6000XP inverter:
  • If the inverter provides the full 100A charging current, the charging time would be:
    (100/100​) ×0.93= 0.93 hours (55.8 minutes)
  • If the charging current is limited to 50A, the charging time increases to:
    (100/50)×0.93=1.86 hours (111 minutes)
These examples show how adjusting the charging current affects the time required to fully charge the battery. Additionally, real-world factors like minor voltage fluctuations and environmental conditions can influence the actual charging time.
dfwtinker reacted
herreraa
(@herreraa)
@jared Just the answer i was looking for EXCELLENT, THANKS!!!!!!!
herreraa
(@herreraa)
@jared Forgot, in what scenarios the charging current in the inverter is not 100Amps? perhaps if using solar only ? thanks
@herreraa, the charge current might be restricted through the settings, or the BMS could limit it based on the state of charge when communicating with the inverter.
