Question System Size
(@sparkied)
Looking at sizing a system for a off grid cabin.
I want and am looking at the EG4 3000EHV, 2 - eg4 ll-s 48v batteries and 6x550w solar panels. I need to power a fridge, microwave, kitchen appliances, small fans, and electronics like tv and phone charger. Wondering if im on the right track with the proper solar array and the bank of batterys i need for this smaller system.
This topic was modified 2 years ago by sparkied
To provide you with an accurate answer, I would need the following information:
1. List All Loads and Calculate Power Requirements
  • Identify all appliances, devices, and equipment that will be powered by the system.
  • Record the wattage or amperage for each load; convert to watts if only amps are given (Watts = Volts × Amps).
  • Categorize loads into continuous and intermittent.
2. Calculate Total Daily Load (in Watt-Hours)
  • For each appliance:
    • Determine the hours of daily use.
    • Calculate the daily energy consumption: ∗∗Wattage×HoursofUse∗∗=Watt−Hours(Wh)perday**Wattage × Hours of Use** = Watt-Hours (Wh) per day.
  • Sum the daily watt-hours for all devices to get the total daily load in watt-hours (Wh).
3. Determine Peak Load (Power Demand)
  • Identify the maximum simultaneous load to calculate the peak demand (in watts). This is essential to ensure the inverter can handle the highest possible load.
  • Add a margin (10-20%) to account for unexpected loads.
Example Summary of Load Calculation
Appliance Wattage (W) Daily Use (hrs) Daily Consumption (Wh)
Refrigerator 150 12 1800
Lights (5x20W) 100 6 600
Laptop 50 8 400
TV 75 3 225
Total Daily Load     3025 Wh
Peak Load: If refrigerator and all other devices run at once, total peak = 150 + 100 + 50 + 75 = 375W
