Change to R-454B on...
Change to R-454B on the Mini Split?
(@scottc)
Is there a release date for the R-454B version of the Mini Split options?
Not that I am aware of. However, I will make sure to update the thread as soon as I have more information on this matter.
(@scottc)
I hope I'm not taking the team by surprise. I'm planning to order a system and install it, but I didn't want to order it now and have it outdated in 2 months. I was hoping the team was already in process of the transition and R-454B systems would be available soon.
Some research I've pulled up ...
The shift to R-454B refrigerant in HVAC systems is set to occur on January 1, 2025. On this date, the Environmental Protection Agency (EPA) will no longer allow manufacturers to build residential ducted and ductless HVAC equipment using the current R-410A refrigerant
This change is in response to EPA regulations mandating the phaseout of R-410A by 2025 due to its high global warming potential (GWP)
Some key points about the transition:
  1. R-454B will replace R-410A in most new air conditioning systems starting in 2025.
  2. The new refrigerant has a significantly lower GWP of 466, compared to R-410A's 2,088
  3. Existing systems using R-410A cannot be retrofitted to use R-454B; entirely new systems will be required
  4. While the official transition date is set for 2025, some changes may begin earlier
(@montufar)
There is currently no official release date for the R-454B version of ductless mini split systems, but manufacturers are beginning to transition away from R-410A. The switch to R-454B is part of ongoing efforts to meet lower global warming potential (GWP) refrigerant regulations. Some brands have announced 2025 as a target year for broader availability. As this change affects both central and ductless mini split systems, availability may vary by region and model. Keep an eye on updates from leading HVAC manufacturers for the most accurate release timelines.
(@john-stewart)
Converting a mini-split to <a href=" removed link " target="_blank" rel="noopener">R-454B is not a simple drop-in. It requires:
  • Ensuring the system is compatible (pressure rating, seals, valves)
  • Using the correct POE oil
  • Professional evacuation, recharge, and possible expansion valve adjustments
  • Understanding it may affect performance and void the warranty
Bottom line: Only convert if the manufacturer approves or the unit is designed for it; otherwise, use a system already rated for R-454B.
