Hybrid mini split u...
Hybrid mini split unit stopped communicating with app
Ravasunpower
(@ravasunpower)
hello, my Hybrid EG$ minisplit unit stopped communicating with the app. Still works with remote. Is there a way to reset it ?
Thanks
Ravasunpower
(@ravasunpower)
Update, i found online that you have to have both solar and AC breakers off for 10 minutes and then it resets the unit and you are able to reconnect to the app.
Ravasunpower
(@ravasunpower)
I might be wrong but this is not in the manual for the mini split unit.
Ravasunpower
(@ravasunpower)
Hello, i am getting repeated W018 code, meaning AC frequency out of range. Why is that? The inverter does work fine.
@ravasunpower Were you able to get the app to connect to the mini split?
Ravasunpower
(@ravasunpower)
@eg4eric  yes, i disconnected both AC and solar from it for 10 minutes and it finally accepted the internet setup.
Awesome! Thanks for sharing!
 bdub
(@bdub)
@ravasunpower  How weird!  I'm having the same problem.  Can't get the EG4 to pair with my Android phone bluetooth.  Are you still using the clunky Solar Aircon app?
Try deleting the app and reinstalling it and let me know if that works please!
Ravasunpower
(@ravasunpower)
@bdub yes, i am using the same app but on iPhone.
 bdub
(@bdub)
That worked for me as well. 😀   Had reinstalled ap with no luck.  Shutting everything down for 10 minutes did the trick.  Thank you so much for this.
