12000XP Low Charge ...
Question 12000XP Low Charge Rate Using Grid
3 Reactions
Discharge Current limit is for both Lead acid and SOC. The inverter should already come preset with that setting. It should only be changed if you want to limit the battery discharge or if you are adding another unit in parallel.
