6000xp Battery Bran...
6000xp Battery Brand Setting
(@kronmags)
I have two 51.2V 100AH batteries from GLCE which are not on the Battery Brand chart and no associated Battery Code.  When I set up my 6000xp, it appears to have defaulted to (or set itself to) Battery Brand 6.  The inverter is communicating with the GLCE's and shows SOC, V, etc.
I'm wondering if there is a better setting that I should be using?  Or is there explanation of the different settings associated with the 19 Battery Codes?
Additional information about the GLCE Battery:
The BMS Model #: UP16S015 v1.3
Max Charge: 58.4V, Cut-off discharging: 42.0, Standard charging current: 50A, Max. Charging current: 100A, Standard Discharging Current: 100A, Max. Discharging current: 100A, Peak Discharging Current: 150A, Protections: OVP/UVP/OCP/OTP/UTP/SCP,etc.
You might take a look at the following doc:
EG4-6000XP-Battery-Compatibility-List.pdf
Never mind, I see you already have.
I am not certain what the next step is.  I really wish that battery manufacturers would list the BMS that is associated with the battery.
Sorry, not much help.
