Changing the Max Ge...
Question Changing the Max Generator Input Power on a 6000XP
(@joekeys)
Due to the unprecedented rains in Panama I need to use my generator for the first time to charge my batteries on my 6000XP system. I understand the default is 9000 watts… I have a 5000 watt generator that should work (albeit slowly) with the new gen-boost software setting. I enabled gen boost from the panel but cannot access the EG4 Monitor Center with an admin ID… (tried admin/admin but that does not work) - don't know what that was set to….
As far as I can tell there's no way to do this from the panel… IS THERE a way to either (1) make this change from the panel OR (2) reset the admin ID without wiping out all of the other settings?
The generator input can be adjusted using Setting 18 on the LCD display,
and GEN boost can be enabled or disabled via Setting 30.
Regarding the issue with logging into the monitoring system, are you using the EG4 app locally, or is the inverter connected to the server?
