Runtime chart
Runtime chart
(@dvsatech)
I'm looking at the EG4 3000 EVH all in one and looking for a run time chart to estimate the run time at different loads (300 watts, 500 watts, 1000 watts, 1500 watts, 2000 watts) and 1, 2, or 3 100Ah batteries.
(@dvsatech)
I found a formula online. With efficiency at 95% is this correct?
Runtime (hours) = (Battery capacity (Ah) x Battery voltage (V) x Efficiency) / Load power (W)
Battery Ah 100.0
Battery V 48.0
Invert Efficiency 0.950
Power (w) 4560.0
Load (w)      Runtime (H:M)
   300           15:11
   500           09:06
 1000           04:33
 1500           03:02
 2000           02:16
This does not include the overhead of the inverter but not sure how much of an impact that adds?
That looks about right.  According to the spec sheet the battery to invert efficiency is 94% and the non-standby idle consumption is approx. 50W.  Depending on how tight you are trying to calculate it could make a bit of difference.
Also keep in mind that due to variations in batteries, wire lengths etc. your specific mileage may vary.  Personally, I like to leave at least 5% overhead when looking at discharge and charge times.
Here is a link to the spec sheet EG4-3000EHV-48-Spec-Sheet.pdf
