Time+SOC doesn't tr...
Question Time+SOC doesn't trigger AC Charge
(@powerup)
12kPv (fw: EAAB-2021) + two 14.3 KW wall mount (Closed Loop / Volt)
Application is TOU exclusively. For the time being I have "Batt Charge Control" set to "Volt"
      "AC Charge Based On" set to "Time"
Every morning the Inverter has started its charge on time @ 09:30
Last night I decided to set the "AC Charge Based On" to "Time+SOC/Volt"
       I was told by SS that this setting means it will be scheduled for Time OR SOC/Volt
The Inverter did NOT start at 9:30, I finally went in to settings, changed the "AC Charge Based On" back to "Time" only and then reset the start time to be 2 minutes beyond that moment.
       The inverter then started to charge (as expected)
Am I misinterpreting "Time+SOC/Volt"? This was the ONLY adjustment made.
Appreciate guidance, welcome to test options to help identify potential anomaly
(@krzysiek_kta)
Posted by: @powerup
In my experience when Wall Mount battery is set to lithium (closed loop) the battery voltage settings do not work - only SOC triggers charging: "Battery SOC and Time (according to)"
On the other hand when battery is set to Lead Acid (open loop) only Voltage settings work:
"Battery Voltage and Time (according to)", SoC doesn't do anything.
Hope that helps.
Brgds
K
(@powerup)
Thank you, I was thinking it could be conflicting with another setting.
