16kwh plus two 14.3...
16kwh plus two 14.3kwh in parall?
 Nick
(@nick)
I've a single 12000xp inverter with two 14.3kwh all weather batteries.   Is it OK to parallel a 16kwh all weather with the two 14.3s?  Does the 16 need to be in the center ("master"), or does it not make any difference what position is in?
Thanks
@nick
The 16-kWh battery is preferred as the master battery; however, if that isn’t possible, it can be added to the existing 14.3 kWh batteries without any issues.
(@jep83)
@eg4eric any word on the UL certification?
@jep83
Nothing yet. I will ask for an update and follow up.
