6000xp paired with ...
6000xp paired with Wall Mount EG4 Comm Questions
Hello,
First time setting up the 6000xp/Wall mount batteries. I have 3 ea. 6000xp's and 2 ea. Wall Mount Batteries and reading the manual it is unclear to me on setting up the battery communication cables and also the paralleling of the inverters. Does anyone have a diagram?
Guidance for paralleling can be found in the manual, starting on PDF page 25 (or page 21 of the manual). For BMS communication, connect the master battery to the master inverter using the orange BMS cable, and link the battery communication ports between each battery with the provided cables. A line diagram for paralleling three 6000XPs is available in the link below:
EG4 6000XP System Wiring Diagrams
@jared
Nothing really states whether to use the CAN or RS485 output from the battery. I'm assuming CA for the EG4 Wallmount batteries?
@ron I recommend CAN communication with the Wallmount batteries.
I have mine wire just like in the first image (the orange line).  and all works great.
@joel-brodeur On the battery are you plugging into The CAN or RS485 port?
@ron Then CAN port.
