Battery SOC inconsi...
Battery SOC inconsistancy
(@dademt)
Have three indoor wall mount units.  2 I have been running for about 6 or so months and the other brand new.  Just switched over to eg4 18k inverters not that it should matter but noticing that my battery readout on SOC is way off compared to voltage.  So the voltage all appears basically equal and the batteries regularly go down into the 20's or below before charging all the way up so I don't think it is a equalization issue but can't figure out why the discrepencies on the SOC.  Any insight anyone?
Posted by: @dademt
-- attachment is not available --
It has been a while.  Has the SOC discrepancy gotten any better after some more charge/discharge cycles?
My 2-battery drift that way as well on SOC but definitely not that dramatically.
I have seen posts on other forums about "resetting" the BMS's through some magic Vulcan nerve pinch, but I have never seen an EG4 tech recommend or instruct a consumer to do it.
Please keep us posted and sorry I wasn't any help.
(@dademt)
@joel-brodeur Glad I wasn't taking a drink reading the magic vulcan nerve pinch.  That was funny.  Appreciate the insight however.
(@wiredup)
I have the all weather Power-pro wall mount with 18k and I am seeing something similar.  Charges up to 99% and within a day or so it's down to 80% with absolutely no load (not connected yet). However the voltage does not change at all. Still working with tech on this.
(@dademt)
@wiredup Did you hear anything back on this yet?  Just curious.
Could you provide the data history to help clarify this issue? Depending on the time frame, the battery drain might be due to the inverter's normal or idle wattage consumption. With typical consumption around 70W and idle usage about 15W, this could amount to a combined draw of approximately 2,040Wh over a 24-hour period.
(@wiredup)
This is the most recent,  the oddity was that the voltage did not change.
@wiredup you might have a look at the following thread:
https://forum.eg4electronics.com/community/postid/12131/
@signaturesolarjess
discusses a way to get the BMS to reset the high and low for the SOC readings?
Looks like a kind of painful way of doing it but if it works....
There was also another thread in which @jared
seemed to imply that you could use the high voltage cutoff to force a BMS reset but I haven't seen confirmation of that.  Here is that thread as well:
https://forum.eg4electronics.com/community/postid/1128/
Best of luck and please keep us posted.
