bms tools communica...
Question bms tools communication
(@bautert)
I have 4 growatt 5000 inverts and 6 eg4 lifepower batteries.  I believe they are version 1, as they do not look like v2.  The batteries do have a screen monochrome screen on front.  I am trying to update the batteries purchased the batteries the end of 2021. I do have the correct cable.
For BMS tools V1 windows - the only version I can find. I have the latest drivers installed and the provided patch cable(rj45-usb). I select baud rate of 9600 and connect cable as described in documentation.  I get an error stating the com is in use, but it is not.  I have tried all addresses and ports on battery.  I only have one battery connected.  I cannot connect to this battery using bms tools.
For BMS test the software opens a port successfully plugged into the rj45 jack on battery or either communication rj45 jacks.  parameters are set to what is called for in the documentation.  When I switch to the batinfo tab the com rj45 ports will blink as the program is trying to establish a connection.  The error on the software tells describes a failure on that address.  I have flipped the dip switches and added addresses to the sequences nothing has worked.
I am unable to get boot information or data from battery.
What am I missing?
Thanks.
(@qstorm58)
Hi Bautert, did you ever get a resolution to upgrading your Eg4-LL version. 1 batteries? I am running in to the same issue. I have two of them and I am trying to get them to communicate 12000XP Inverter. I have tried BMSTools and BMStest on a windows machine, and have had no luck, luck with upgrading them..
(@bautert)
no luck using logic or any other method. It opens communication with bmstest, but does not identify any addresses. I know on some batteries the dipswitches were reversed so I tried what I thought would be opposite not luck. 0001, 1000 1110, 1111, or 0000  Cant even connect using bmstools.
