Could I be charging...
Question Could I be charging too slowly?
(@powerup)
12kPV + two 14.3 Indoor WallMount 280AH
I am cycling the batteries once a day 100->20->100.
The Technical Specifications page for those WM Batteries says to charge them between 60 - 140A "Charging Current"
https://eg4electronics.com/wp-content/uploads/2024/04/EG4%C2%AE-Indoor-280Ah-Battery-Specifications-Sheet.pdf
Can someone please guide me why going below 60A would be detrimental?
I have been charging them over 6h:45min at a rate of 4kWh [C/.14]
To maintain that rate the inverter has been delivering between 73A - 74A but since that is for two Wallmount batteries the effective rate is only ~37A to each battery.
I am concerned that I may be doing something incorrectly since the spec sheet specifically outlines 60 - 140A Charging Current for those WallMount batteries.
I am discharging the batteries over 3 hours @ ~156A. Effectively 78A to each battery and inside the 60 - 140A recommendation for Discharge Current Rate.
Appreciate your insights and guidance,
I don’t believe charging with lower amperage than the recommended will damage the batteries. The main things would be slower charging and a potential for the battery cells to become imbalanced over time. Other than that, there shouldn’t be any major issues.
(@powerup)
Thanks, I infer that charging below 60A could cause imbalance? Is there docs that can offer some more visibility?
I was considering going slower (many research papers suggest a C/.1 rate) but maybe the BMS for theses batteries act oddly at that rate.
This is based on my research, but I’ll reach out to our battery technician to get a definitive answer.
I checked with our technician, and they confirmed that charging below 60A will not cause any battery cell imbalance.
(@powerup)
@eg4eric Thank you for checking it!
So I presume there isn't a reason that the battery specs have a lower limit for charging Amps?
@powerup
I don’t have an answer at the moment, but I can consult with our battery technician and follow up with a clear and accurate response.
