LifePower4 BMS firm...
LifePower4 BMS firmware bug/failure... no auto re-start after LV disconnect
(@dtbaker61)
I have 3x Lifepower4 48v batteries installed at an off-grid site. we had some really solid cloudy days, and then some snow.... eg4-6000xp disconnected load at 46v as programmed and went into standby as expected.
But then, this morning, only one of three batteries woke up after sun was up. I went to site around 10am, and noted that ONE battery was blinking "run" condition and taking charge.
I turned off the battery/bms breaker on the ones that were not running, waited a moment, and turned breakers back on. The batteries resumed normal "run" blinking, and started taking charge. This indicates to me that either the internal BMS's are damaged, or firmware has a bug disallowing auto recovery after a LV shutdown at 46v. My understanding from documentation is that the lower limit for recovery is 44v, so all the batteries should have been fine.
I am not sure what version of firmware is in the batteries, they are less than a year old though. I am running them 'open loop', so they are not connected to Inverter comms.
I would appreciate detailed step-by-step instructions on how I can obtain the latest firmware for the Lifepower4 batteries I have, and how to install the update in each from a laptop. Then how to check the health of each battery and BMS.
It may be related to the temperature reported by the BMS, as charging should occur within the range of 32°F to 131°F, while discharging should occur within the range of -4°F to 140°F.
A guide for the BMS Test software can be found in the manual here:
EG4 Lifepower4 48V Manual
A guide for the firmware update will be available in the firmware file folder, which can be accessed here:
EG4 Lifepower4 48V Firmware Documentation
If you have any questions, feel free to let me know!
(@dtbaker61)
@jared , the issue was not temperature related. The "solar enclosure" was well above 32F. The issue is that 2 of 3 Lifepower4 batteries failed to restart automatically after a low-voltage load disconnect at 46.0v. As reported, the "run" LEDs were not lit well after sunrise on two of three, but did reset and "run" after I manually turned off the battery/BMS breakers, and turned back on. There was a weird buzzing noise from one of the batteries for 20 seconds or so, but quiet after that.
I have not attempted to use the BMS test software to see if there is any permanent damage reported yet.
I would like to know if there have been any firmware updates made available in the last year that contain fixes to address this bug, or if this is a "new" bug that has not been addressed yet.
All firmware update changes for the 48v Lifepower4 V1 can be found here: Lifepower4 V1 – EG4 Community Forum
(@dtbaker61)
@jared , I just read thru all release notes for updates since v3.1... there is nothing written up to address the bug I have experienced with lifepower4 batteries failing to recover from LV disconnect by Inverter when running in open-loop mode inverter control by voltage.
I would like verification that you will pass this trouble ticket on to whoever is responsible for verification, testing, and fixing the lifepower4 firmware. I can help software dev team develop a test procedure to duplicate conditions if needed.
 Arne
(@arne)
I want to update the Firmware for the v1 LiFepower4 48V 100AH but need help what to do next. attached is a screen shot of the current firmware. I have 6 of them, however 3 of them failed the Get Boot Information.
Screenshot 2024 12 19 at 5.09.20 PM
I recommend verifying that the device address is set to 0 and the battery dip switches are configured to ID 0 before updating the battery. Also, here is a guide for updating the Lifepower4 V1.
