New EG4 battery fir...
New EG4 battery firmware updater
(@texas-randy)
I just got the new EG4 battery updater box and am having a problem with getting the 485 firmware to load. The 232 comm file loaded without any problem but when I try the 485 update it trips the fault light.
I used battery comm for the RS232 update and the 485 input for the RS485 update.
Do I need to remove the RS232 update file from the device and try again even though the manual states you can have the .hex and .bin files on it ?
Are you using the correct cables for each update?
I apologize, ignore my last post. You only need 1 cable, which is the one that the adapter comes with.
You can try removing one file, but you should be able to do it with both files in the adapter.
(@texas-randy)
Deleted all files and loaded only the RS485. bin file, same thing. Fault trips.
Which battery model are you attempting to update?
