Newbie Help, Missin...
Question Newbie Help, Missing Battery information on Monitor Center
9 Users
3 Reactions
(@brandon314159)
I have Wallmount batteries and switching the 'brand' to 01 brought this data up on my display.
I either overlooked that detail in the configuration process or it wasn't documented well. Either way, much better!
Thanks!
(@ibuprofen5973)
I have two Wallmount AllWeather batteries and the battery parameters never showed up for me.
I had lithium brand set to 0:EG4.  Changed to 1 because of what I saw posted here and the battery parameters are displayed!
Thanks for the help!
(@gtsquires)
I had the same issue, but it begs the question: Why would you NOT set the battery type to EG4 rather than "1"? They are EG4 batteries. I have wasted a lot of time trying to figure this out.
(@chill633)
@gtsquires Because the manual and my configuration page says otherwise?
From page 24 of the FlexBoss 21 user manual, v1.3.2
"For communication with EG4® batteries, select “Lithium” under “Battery Type” and then select “0:EG4” under “Lithium Brand”"
Then, when going to my config screen I see:
For the record, setting to 1 and rebooting the BMS on each battery fixed it for me. It is now displaying the details in the web monitor screen.
Page 3 / 3
