6000XP Generator Ch...
[Solved] 6000XP Generator Charging
5 Reactions
(@johnnyg)
One more thing to add.
We are building a new house and every time I plug the generator into the 6000XP a ground fault outlet in the house trips. I found a neutral bond under the cover of the generator and removed it. Now the GFI didn't trip. I set the inverter to be the bonding point in the program setting. Is this a common thing to do?
@johnnyg Is the neutral bonded in the new house panel? Is the inverter also neutral bonded? If yes to both, you created a loop.
(@johnnyg)
Good news, the system is changing!
From this picture can you determine how much charge is going to the batteries?
Could I increase the charge rate?
PXL 20241122 164045506
@johnnyg There are some settings that will increase the charge limits to the battery.  I am not certain if they are available on the screen or the phone app.  You may need to set them through the monitor portal.  You will also need to be very careful about not sending too much current to the batteries and/or drawing too much current from the gen.  It kinda looks like the battery charge limit is currently at 30A.
Do you have access to be able to use the web monitor?
(@wvaoffgrid)
Do you have to manually start and stop the generator? Or is there a way to have it auto start when the batteries get down to a set point?
@wvaoffgrid with a two-wire start/stop, you would not need to manually start and stop the generator.
(@johnnyg)
We have no Internet access and the generator is manually started.
@johnnyg
Just as a follow-up, I THINK it is setting 6
Maybe one of the EG4 technical experts can help out on this.  I am just not certain which settings are on the screen to increase the Adc charge rates, and I would hate to point in the wrong direction.
@Jared has been exceptionally helpful to me so maybe he will chime in.  Fingers crossed.
Page 2 / 3
