Chargverter GC sett...
Chargverter GC settings
(@papote)
I just bought a Chargeverter GC and plugged it into my busbar that feeds 2 Orient Power 48V 100 Ah 5.12Kwh LiFePo4 batteries. I have it connected to a 7,000 Watt 240V split phase gas electric generator.
I noticed that it never goes any higher than 20 Amps on the DC side.
Should I change some configuration?
Chargverter settings
What is the current set to in the settings?
(@papote)
@jared I have all the default settings. I believe the carge is at 54V
@papote I would verify that the current is not set to 20A in the settings.
(@papote)
@jared i has moved up to 36A, but wouldn't go over 20A. I haven't tester yet with raining the voltage, yet.
@papote Could you post an image of your settings?
(@papote)
@papote What is the model of the generator? Also, can you show a picture of how the connections are made?
Probably a silly question but... I notice that the recommended charge rate on that battery is 20A but "can charge up to 100A".  Could the BMS be regulating the charge current.  Maybe there is a setting in the BMS that you can set to increase it?  I don't know much about the Chargeverters, I am assuming that this open loop or is the comms between the battery and the chargeverter?
Just an idea.
(@papote)
Raised to 56V and now it goes all the way to 100Amps.
Is there any way to have it communicate with the batteries that use Pylon protocol on RS485?
@papote EG4 protocol is currently the only supported option on the Chargeverter GC.
