EG4 18pv inverter w...
EG4 18pv inverter will activate generator on a power deep from the grid
(@jpereda1)
18kPV will activate generator when sensing a power dip from the grid. This is on the power backup setting. I thought the system should have use the battery to support the loads in this type of event.
If you have the settings correct, it should use batteries. Make sure you have Power Backup-Enabled and make sure that Battery Backup mode is disabled
