EG4's in "split pha...
EG4's in "split phase"
(@frugal-farmer)
I have 2 questions regarding my 240 volt 2 inverters in split phase mode.
1) I am only able to connect my 240 generator for charging when I put my inverters in "stand-by" mode. Is my setup unable to charge via a generator in the online mode so I am able to use electricity when the generator is being used (...and when solar is present also) to boost battery percent of charge?
2) I have noticed the 2 LED's on the face of the inverters blink in unison in varying patterns on occasion. What are the patterns indicating?
Thanks in advance.
Which inverters are you using?
(@frugal-farmer)
EG4 3000 EHV-48.
(@frugal-farmer)
Anyone else out there have this same (#1) issue with these inverters or do I have a setting wrong. Seems odd the manufacturer would disallow generator charges only in stand-by mode.
