Existing Flexboss21...
Existing Flexboss21, 3-280Ah Batts adding 2- 314 Ah batteries BMS not working
(@cptmorgemaker)
I currently have a flexboss21 with a gridboss, 3- EG4 280 ah indoor batteries, 30 Canadian Solar panels hooked up and running for about 4 months now all has been fine and have been doing net metering. I bought 2 new 314 batteries to add to the mix. I added them to the system putting them as the Master and 1 then the 3 280s follow 3,4,5. The wiring drawings are a bit confusing as the wording is different then the pictures illustrated in the manuals. I currently have the inverter cat5 going to CAN then port 1 has a terminator, port 2 feeds the next 314 to port 1 then port 2 goes to my 280 and those daisy chain through the battery comms. The wire from the 2ed 314 and all the 280s have only wires 7 and 8 hooked up in the cat wire. I made them and tested them with a meter they all tested 7-7,8-8. After getting it going and batts all to 100%. It seems to work great except for AC charge. It will not allow more then 31 Amps. All my settings are correct and been checked about 10 times. I have tried other methods i have seen others post that they were told to do from signature solar and still it does not work. I switched protocols on the batts to Lux  on the 280s still no go. The batteries are currently at 20% and the BMS is sitting at 31Amps. For all i have gathered this is a comm issue with why the BMS is not doing its thing. I have power cycled everything several times in the correct order and all and still it will not budge. Please help I have emailed and tried calling support to no answer. I guess i should have just stuck with 2 more 280s and kept it all the same but was liking the little additional battery capacity. Hope I can get this fixed otherwise I just have to run them in voltage which is not ideal.
(@cptmorgemaker)
Got it fixed the 314's needed a firmware update it seems. Eg4 forced a update and system is working flawless. Awesome help as always.
@cptmorgemaker
I'm glad you got it working!
We will be posting more announcements and new firmware updates on the forum.
If you have any questions or need assistance, feel free to reach out.
(@cptmorgemaker)
Sounds Good, Great support and Great products
Thank you
