Grid pass through o...
Grid pass through only or grid pass through with battery charging
How does the 6000xp decide to pass through grid to the loads or pass through grid to the loads and also charge the battery?
What are the settings needed?
I want to obviously use all of the power the solar panels create, but if I run out of battery a few hours before the panels start to produce power I don't want the grid fully charging the batteries. So many variables
When connected to the grid, the loads will switch to grid power if PV power is unavailable, and the battery reaches the on-grid EOD. To enable AC charging, you’ll need to activate it either through the LCD display or the monitoring system.
So grid charge is completely manual function?
AC charge will be automatic once configured.
