Help! - Had solar p...
[Solved] Help! - Had solar panels, EG4 Inverter and Batteries installed in 7/2026- Has never been right.
6 Users
(@dutch-34)
Hello. I’m new to the forum and I’m hoping it to get some guidance or direction on what to do about the Solar power system and storage that I had installed on my home almost a year ago. I have 42 Canadian Solar Panels with Enphase Micro Inverters, EG4 18 Inverter and three EG4 12kw Batteries. We have not been able to use the batteries at all without significant problems. When using we a getting significant surges in the home that dim all the lights associated with the backed up circuits, so much so that it causes the router in our home to lose power and reset and at times will power down our TV. This continues in cycles of appx 3 minutes repeatedly. There is also an unsettling electrical sound that occurs at the same time. This happens primarily at night, but sometimes during the day as well.
The installer has been out many, many times. They even replaced the inverter under warranty believing that is the problem. However that did not correct the issue. They changed the breaker and upgraded the wiring to the breaker, but no luck. I believe the installer has and is trying to correct the issue, but they have not been able to correct the problem in nearly a year. I honestly believe they do not know what to do to fix this, at this point.
So I have a very expensive system that does not work. The inverter has been throwing a “Bus Voltage High” fault repeatedly. I have since turned off the batteries at the breaker on the inverter to avoid damage to appliances and electronics. Also, for personal safety. This seems unsafe. Sorry for the long post, but I really dont know what to do at this point. Any help is much appreciated.
@dutch-34
Good morning!
Have you talked to our Tech Support team?
If you would like, you can send me a DM with your name, number and email and I can have someone reach out to you.
(@dutch-34)
I spoke with someone with support on Friday. He spent a lot of time with me and my installer on the phone, which I appreciate. Made several changes. But unfortunately, those changes did not help.
(@holymaniac)
I have also had so many problems. I regret getting EG4. Most of my issues seem to have been resolved after months of frustration and frequent work with tech support. The one remaining issue is that daily the feed watts from the solar panels creeps down after 12 noon to nearly zero and then goes back up by 1 pm. Sunny day, no shade, no cause found. Tech support can't figure it out.
(@lyrawinslow)
I've seen some setups which ended up being a small problem in the overall configuration of the system and not a bad inverter or battery.
The wiring was checked, the inverter was replaced, so I would probably take a look at a couple of other items:
Will this occur only when the house is on battery back-up or also while plugged in?
Are the surges occurring when a particular appliance is turned on (AC, heat pump, well pump, refrigerator etc.)?
Is all three batteries in communication to each other and sharing the load evenly with an inverter?
As you are employing the Enphase microinverters, I would also want to double-check the AC coupling setting and how the system is performing in solar production mode during its backup.
I think more attention should be paid to the inverter settings, battery communications and AC-coupled solar behavior than merely to the hardware, as the "Bus Voltage High" fault makes me think so.
Does there appear to be any other warning/fault history from the inverter out of curiosity when the surge occurs every few minutes? This could help you identify what it is that you're actually reacting to.
