Question [Solved] latest firmware
4 Reactions
(@maddmatt1962)
looking for the latest firmware on the 6000xp mine are ccaa-160B0B
If you use the web monitor, you can go to Maintenance - Remote Update - and click on Standard Update
If you are using the app - connect to internet - click download firmware and follow on screen prompts.
Personally, I have had better luck with the web monitor but YMMV.
(@maddmatt1962)
@joel-brodeur thank you I saw that you could so i will go that route
The latest firmware for the 6000XP would be 190D0E. This video will show you how to update the firmware for this inverter.
(@maddmatt1962)
@jared Can you download the firmware to 2 inverters at the same time and restart both
@maddmatt1962 for a seamless update, I recommend powering the router from a source other than the inverters during the process. That said, that would work.
